Closing Read Only VIs slow
Hi, I have a weird behavior on some of our PCs.
We changed our TortioseSVN setting for the LabView folder to "Needs-lock", which essentially makes all LV files read-only unless you want to change it. Works fine on most of our systems.
But on a few PCs, the VIs take about 5 seconds to close, while freezing only LabView. Windows still responding. CPU/Ram usage is below 60%.
Running the VIs works fine.
Any Ideas what would cause this?
We use LabVIEW 2020 32b.
(1,134 Views)
I'm guessing some things want to recompile but can't?
Bill
CLD
(Mid-Level minion.)
(1,100 Views)
Any ideas on how to prevent this? Its weird that it just on a few PCs.
(1,072 Views)
