How can I get multiple plots on an XY Graph?
I am trying to create a force vs position graph that can compare multiple plots of data on the same graph. I cannot seem to get an XY graph to show more than one plot at a time.  I've tried using the 'merge singals' function but found that this can only be used with dynamic data. Is there a way to do this and XY graph?
-Matt
(3,989 Views)
To get multiple plots on an xy graph, you wire in an array of xy clusters. The xy graph can take in either a single xy cluster or an array of clusters. It will plot multiple traces on a single xy graph if you wire in an array of xy clusters. This is also shown if press Ctrl-H to get the context help open and hover over the xy graph.
Hope that helps,
-Tim
(3,981 Views)
Attached is an example I made for someone else. It actually does a bit more than you need in that each time you press the new plot button a separate plot is created, but the important thing is the concepts behind it.
Note that the points sort of dance around the plot area because the X and Y values are derived from random number generators.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,973 Views)
Finally got it. Thanks guys!
(3,960 Views)
