Path to TopVI
Hopefully this is a simple one...
I am using LabVIEW V 7.1. How can I obtain the path of TopVI from a subVI that resides in another directory?
(3,725 Views)
Use the VI Server functions coupled with the Call Chain function. The Call Chain doesn't care about physical locations.
Example:
Message Edited by smercurio_fc on 07-23-2007 01:19 PM
(3,719 Views)
Very clever - thanks. The call chain can be lengthy and the TopVI is not always the same name.
From the output "Call chain" I put in a "Array size" and subtracted 1 for the input to the index array.
Thanks again.
(3,711 Views)
OK, so you're really want to know the parent VI rather than the "top" VI. In that case, the index of 1 will work for you.
(3,702 Views)
