How can I convert array of Boolean values to array of text
Good evening
Hai I am working on a project in LabVIEW and I am doing a report for all my founded values in the project and now i want all my values in text format that is in TRUE or FALSE but I am done with getting the values as 0 or 1 in a table but failed in getting them in text format
any help will be appreciated
Thank you
Message 1 of 25
(6,979 Views)
I see a lot of broken wires.  I'm assuming that is where the problem is.  You have an array of doubles and are trying to add to that strings.  You can't have different datatypes in an array.
Convert the numerics to strings first.  Then add the strings to your array.
Message 2 of 25
(6,976 Views)
I want to load the greater than output to build array for reading the values into table
Message 3 of 25
(6,974 Views)
All the broken wires are due to the loading of greater than output to Build array
Message 4 of 25
(6,971 Views)
Use a FOR loop.
Message 5 of 25
(6,970 Views)
Functions -> Programing -> String -> Array to Spreadsheet String
Message 6 of 25
(6,924 Views)
I initially tried that, but the Array To Spreadsheet String does not accept an array of Booleans.  It only likes floats, integers, and strings.
Message 7 of 25
(6,913 Views)
Convert the boolean array to num.
Coerce to Type (where type is an array of enums of "False","True")
Then Array to Spreadsheet String.
Message 8 of 25
(6,901 Views)
Hai Good Morning
The VI you replied is working but it shows error "You have connected two terminals of different types.
The type of the source is string.
The type of the sink is double [64-bit real(~15 digit precision)]" while loading it to build array. help me out for solving this thank you.
Message 9 of 25
(6,870 Views)
IMHO You need to go through basic LabVIEW Tutorials, Mainly on data types and Arrays.
Array will support for Same Data Type, You are trying to build String with Numeric datatype.
Based on your snippet try building after converting to String Datatype.
Message 10 of 25
(6,863 Views)
