11-10-2009 04:52 AM
I am working in a LabView project for some months.
Last Friday, Whem I was working on a new feature, LabView crash and close (it's normal to happened), but now when I try to open this project or another one the Labview software close immediately and I cannot open it.
I don't have problems to just open a simple subVI using a "file->open" menu, but I can't open my project (file->Open project) in my computer.
I make a copy of this project
and I try to open it in other computer and it works fine, so the problem is in
my computer.
I try to remove LabView Software e install it again yesterday but the problem still happen.
What can I do? I lost two days trying to make it works, but I didn't have success and I'm late on my project.
Thanks in advance
SB11-10-2009 04:55 AM
11-12-2009 07:21 AM
What version of LabVIEW are you using?
Does this error happen when you open any VI or only when you try to open a project?
Regards
Luciano Borges
National Instruments Brazil
11-12-2009 07:40 AM
Actually, that's not normal.. Something is wrong.. somewhere...
sbencke wrote:when I try to open this project or another one the Labview software close immediately and I cannot open it.
It appears to be a global problem and not directly related to your project. Which is good and confirmed by the following:
sbencke wrote:
I make a copy of this project and I try to open it in other computer and it works fine
Now to the root cause...
sbencke wrote:
>>>>so the problem is in my computer. <<<<
Yes, it does appear that the problem is the computer. Especially since you've already re-installed LabVIEW and that the same code is fine when using another machine.
Although I suspect you are running Windows. Probably XP or VISTA.. I will still ask the question:
What OS are you using? Which version of LabVIEW are you running? When running the project on the other computer, does the other machine run the same version (installation) as the machine giving you problems?
The problem seems to point to the OS. Or some sort of corruption within that PC
11-12-2009 08:53 AM
Well, I'm using Win XP - SP2 and I'm using LabView Version 8.
The problem is not in my project because I test it in another computer and it works fine.
Yesterday, I uninstall Labview again and them I use a special program to remove all references of LabView in the Windows register and so on. After that I install LabView.
After this steps, I can open my project without problems, but I'm having another crazy behavior. When I try to open the Controls/Function Palette using the menu or the right button of the mouse, LabView hung and close.
I think I will have to format my computer and reinstall my Win and ALL MY PROGRAMS, so this is a terrible solution.
Somebody has some idea ?
Thanks in advance.
11-12-2009 10:30 AM
sbencke wrote:Well, I'm using Win XP - SP2 and I'm using LabView Version 8.
Thanks in advance.
Hmmm. this sounds a lot like the behavior I noticed three weeks ago on my PC at work. LabVIEW (8.6.1 and 9.0) crashing when loading palettes (I load mine on launch.) I also had trouble with MS Office and a few other apps running verry slowly. IT investigated and determined it was some undefined malware on my PC that snuck by our firewall on an attachment recieved from a co-worker in Shanghai. One other machine was hit at the same time so guessing the suspected cause was a process of comparing likely causes that were common between the PCs. We wound up reimaging both machines and I wound up rebuilding everything! Good luck
11-12-2009 11:39 AM
Unfortunately, Jeff's explanation does sound right.
I've had a similar experience a while back. I noticed a feww applications acting up and shutting down for no reason. If you look at the processes in the Windoze Task Manager, you may find some obscure entity. That's how I found the culprit. Even after searching and hunting it down, it would morph itself with a new identity, so I ended up re-building the PC from scratch 😠
That's when I invested in Norton Ghost. And make LOTS of backups (after the installation of any application). That way, you can restore everything easily in the future. And keep your files in a separate partition. I separate the OS from Applications and Files are on their own. A 4th partition (or other drive - usually) contains backups.
11-12-2009 12:49 PM
Ray.R wrote:Unfortunately, Jeff's explanation does sound right.
All great Ideas Ray!
Remember to back-up your LabVIEW.ini files first I forgot this and it made me very grumpy for a few days
11-12-2009 03:07 PM
I keep forgetting to backup the LabVIEW.ini files..
Thanks for reminding me.. 🙂
06-04-2010 12:44 AM
I am having the same problem. Labview crashes when i open any project window. I Think
this problem started arising after i visited some unfamiliar websites. Not only labview, some
other applications are behaving erratically. Ran all the anti-virus softwares , but even after
cleaning the virus, the problem is still present.
Great help if someone knows how to fix this problem without formatting windows!
