How Can I Fix it!
I have a build array problem. In my attachments is clear about my problem.
(3,761 Views)
Well, you are using way too much code! All you need is keep the 2D array in a shift regsiter of the FOR loop and use replace array subset to fill in the formatted data as you go. Try it!
You are also autoindexing on an arrau with a single element (180) forcing the FOR loop top stop after one iteration. use a scalar instead.
(3,750 Views)
Try Replace Array Subset instead of Insert Into Array.
(3,749 Views)
Accepted by topic author keremgeliz
Try this:
(I would actually recommend to use a table indicator where you set the row and column headers according to the information of the file, not shown)
(3,733 Views)
Yes its fix now Thank you.
(3,710 Views)
How can i do it with excel file. (read excel file and write excel file like this example)
(3,705 Views)
See this recent answer.
(3,699 Views)
