04-24-2014 08:57 AM
I have a build array problem. In my attachments is clear about my problem.
04-24-2014 09:04 AM - edited 04-24-2014 09:06 AM
Well, you are using way too much code! All you need is keep the 2D array in a shift regsiter of the FOR loop and use replace array subset to fill in the formatted data as you go. Try it!
You are also autoindexing on an arrau with a single element (180) forcing the FOR loop top stop after one iteration. use a scalar instead.
04-24-2014 09:05 AM
Try Replace Array Subset instead of Insert Into Array.
04-24-2014 09:23 AM
Try this:
(I would actually recommend to use a table indicator where you set the row and column headers according to the information of the file, not shown)
04-24-2014 09:49 AM
Yes its fix now Thank you.
04-24-2014 09:53 AM
How can i do it with excel file. (read excel file and write excel file like this example)
04-24-2014 10:03 AM
