Hiding Menu Ring Drop-down
Is there a way, during development, to hide/disable the appearance of the drop down arrow associated with a Menu Ring indicator.  See the attached image.  The control, obviously, has the drop down, but the indicator (of the same type) also shows the drop down, even though there is no ability to select anything.  The particular GUI I've inherited has very limited real state, and getting rid of the drop down (on the indicators) would allow me to achieve my objective.
Message 1 of 8
(5,519 Views)
Hi bean,
use a string indicator instead of a ring indicator…
Why use a FP element with a dropdown menu when you don't need this feature?
Message 2 of 8
(5,512 Views)
Right-click >>> Customize
Click the "wrench" to switch to customize mode
select the arrow
Use the reorder drop down and move to back
Done
Ben
Message 3 of 8
(5,504 Views)
The problem is that the output required is of numeric (I16) format.  Actually, I have ten+ such drop downs that are contained within a larger typedef, and that cluster is fed into several routines, and also displayed (thus this indicator) on the front panel.  So I don't want to create a new type that requires some conversion ahead of the indicator
Message 4 of 8
(5,475 Views)
I tried the "Move to Back" solution and, though it does remove the drop down, two issues remain.
1) the size of the control remains the same.  In other words, the drop down is gone, but the space it took up remains.  And when I try to shrink it in size, the text is overriden and the size is always a minimum of SizeOfDropDown (if that makes sense).
2) If I understood your instructions, I followed the steps within the Type Control (ctl) window.  However, I only want the indicator to have this behavior, not the Control.  Due to issue #1, though, this is a non-issue.
Message 5 of 8
(5,467 Views)
Accepted by mrbean
1) In the same screen that you did the "Move to Back" solution you need to resize the text box containing the text.
2) You need to use two different controls then - one when it is a control and one when it is an indicator.
Message 6 of 8
(5,459 Views)
Hi bean,
Are your dropdowns using a fixed set of options (as they should within a typedef)? Why not use enums then?
For enums you could use a simple FormatIntoString and display the enum value it in a string…
(I'm a big fan of separating data handling from UI representations! :D)
Message 7 of 8
(5,440 Views)
@GerdW wrote:
Hi bean,
Ditto that!
I wish I could recall the exact quote by Micael Avaliotis who once wrote something to the effect;
Your GUI display should not dicate how you represent the data in your code.
Ben
Message 8 of 8
(5,434 Views)
