Hide/Show button Control Panel
hello folks!
I want to show some boolean buttons on the control panel only if another boolean button is true - and hide them if the button is false.
Been reading some posts but could not figure out how it works with visible property...
Thanks for your help and greetings from germany!
(6,585 Views)
Accepted by jobauer
Right click on one of your buttons and select Create->Property Node->Visible.  You now have a way to make that button visible or not.  I would recommend using an event structure and create a case for the controlling button's value change.  Just set the visible property of your other buttons based on the value.
(6,576 Views)
use property node-->visible
(6,573 Views)
Thanks a lot
I did not find the "change the wire" option so i did not realise how to get the visible property to accept an input!
(6,562 Views)
