‎06-16-2009 09:53 AM
I am acquiring data in the format of string. My data contains the information of time in style 00:00:00 (hour:min:sec) and number value in the style of exponential. I want to plot my number value against time. I have already converted this string number value to my decimal number and also the time data to number but without conserving my time style (00:00:00). I want to convert the time string format to decimal format while keeping the same time style (00:00:00) in order to plot. Can someone suggest me how to convert the time format to decimal number (conserving the time style) in order to plot the value or is there any possibility that I directly plot the string data against each other?
Secondly, how can I make the exe file in order not to access the code (block diagram)?
‎06-16-2009 11:30 AM
First, please use something descriptive in the subject.
If your dt is not constant, then you need to use an XY Graph.
Whether a normal graph or XY Graph, you would need to format the x axis to show absolute time. right click on the graph and select X Scale>Formatting.
If you have the pro version of LabVIEW or have purchased the app builder, you can create an exe.
‎06-17-2009 04:17 AM
First of all sorry for not using proper subject because after posting this query I noticed about it.
Anyhow, I have already tried to use the XY-graph but it is not taking the data directly. X-axis and Y-axis are taking data dynamically and in number format, but my time data is in string format 00:00:00 (HH:MM:SS), when I tried to wire the X-axis of plot to my time string value it is broken line means it can not connect so I can't plot the data directly. I think first I need to convert my string format to some other format and then I can plot. Actually I want to plot the data and time coming out of my device and I do not want to use my time clock of computer. Can anyone guide me how to solve my problem?
Also, I want to save the my data in file, but the problem is when I open spreadsheet and write data in it, new data over-writes the previous data and I could not make the log file. Can any suggest me what to do to store the data in the excel spreadsheet?
Lastly, which vi can I use to make the exe file, I am using LV Pro 8.5?
With regards
‎06-17-2009 04:44 AM
‎06-17-2009 05:33 AM
I think there is no need of report generation tool kit, if I want to just write some data in a file and then read it. LabVIEW is providing vi's for writing the data in file. The problem is when I write my data in spreadsheet, it overwrites the data and when I open my file I just see the last data.
Secondly, dennis has wrote in his reply, if I have the LV Pro. ver. then I can convert my vi into exe, in this case there is no need for application builder toolkit.
What do you say about it?
But my main question of plotting the data is still there!!!!!!!
‎06-17-2009 06:31 AM
In your original post, you said you had converted "time data to number". If you really had, then you would not have a broken wire. Did you in fact, do the conversion? If so, how did you do it? A Scan From String function wil do the job.
If you are using the Write to Spreadsheet File function, it has a Boolean input to append or replace the file. Have you set this value correctly?
If you continue to have problems, you should attach the VI you've written so someone can look at what you've done.
‎06-17-2009 06:49 AM
‎06-17-2009 07:13 AM
‎06-17-2009
08:48 AM
- last edited on
‎05-01-2025
04:24 PM
by
Content Cleaner
Here is the help file for the Format Specifier Syntax. Look at the relative time syntax that Dennis had mentioned.
