Help creating instrument driver from dll
Hello everybody,
I need to create an instrument driver for a DAQ. I was given a dll; but I don't know how to proceed.
I have attached the dll.
Any help will be highly appreciated
(2,670 Views)
You could start with Tools>Import>Shared Library(dll). This will create wrapper VIs with the Call Library Function Node. Assuming that the import is successful, then you would need documentation from the vendor on the functions in the dll so that you what each does and what parameters to pass.
(2,660 Views)
