Help Build pmw control with accelerator and arduino
good night,
i am new to labview
pls help me to build a project or give the design,  because im confused how to connect accelertor to PMW with arduino,
This the rules:
Create a program using LabView configuration between the sensor
Accelerometer with the speed of a DC motor is used. Where speed motors
DC will change according to the level of the tilt sensor accelerometer.
Im waiting your aswer,
please share .vi
Thank & Regards,
Stew kidz
(3,827 Views)
If you are asking us to do your homework, you are not going to get very far.
This is not a school, we don't teach LabVIEW.
You should start by going through the free Linx tutorials at the LabVIEW makers Hub since you are using an Arduino
https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
And you need to make an attempt to write the program yourself, then come to us and show your code when you get stuck.
=== Engineer Ambiguously ===
(3,822 Views)
Hello  RTSLVU,
Thanks you for your solution,
But now im have other problem,
when My accelerator on 0 degree labview read the value 1,6, and when my accelerator on 90 degree the value is 1,9.
And when my accelerator on -90 degree the value is 1,3.
How to convert it to degree??
Stewkidz
(3,782 Views)
Accepted by StewKidz
Hello
TRY This and Enjoy 😉
(3,771 Views)
SEMAK, I'm guessing your VI implements a simple y = mx+b function.  In cases like these, it's more helpful to push the poster towards that path than create it for them.  It's the "teaching to fish" story.
(3,766 Views)
