Hello I'm looking for the subroutine in labview with the same function of SendByte () in CVI
For my experiment I use serial port Rs232 to communicate with the device.
I've the program to do that in CVI, in the CVI I use the command SendByte () but I can not find the same subroutine in Labview 2015, Do you have any suggestion?
(1,798 Views)
I recommend to use VISA. You have to install that after you installed LV, otherwise the functions are not included in the palettes...
Norbert
Expert: Geometry
(1,788 Views)
Look into VISA. There is a VISA Write function. If you write one character (it's a string, so you need to convert the byte to string), it should be the same as SendByte.
(1,786 Views)
