Having AI and DI at the same time using DAQ assistant
I want to have data acquisition of some analog and digital ports using DAQ assistant, but it gives me error of "The specified resource is reserved". I was wondering if anybody knows how to do that using DAQ assistant.
Thanks.
(2,892 Views)
I suggest you to use DAQmx VIs, which give you more freedom in optimisation of code.
- HS
(2,882 Views)
Thanks.
I have not used DAQmx Vis. Do you know any good website/book that can help me? (unfortunately the examples are not clear enough for those who have not used the palette yet)
(2,873 Views)
hi,
this link can be of your use http://decibel.ni.com/content/docs/DOC-15408 .. just configure a little as per your need of AI ..
HS
(2,870 Views)
Thanks. I appreciate it.
Baran.
(2,868 Views)
Smiley Happy Kudos are good for appreciation ..
Any way if you need any further explanation of that VI please post here.
- HS
(2,864 Views)
Good to know. I was not familiar with the concept of Kudo. tnx.
(2,860 Views)
