‎04-28-2011 05:36 PM
I want to have data acquisition of some analog and digital ports using DAQ assistant, but it gives me error of "The specified resource is reserved". I was wondering if anybody knows how to do that using DAQ assistant.
Thanks.
‎04-29-2011 01:29 AM
I suggest you to use DAQmx VIs, which give you more freedom in optimisation of code.
- HS
‎04-29-2011 10:34 AM
Thanks.
I have not used DAQmx Vis. Do you know any good website/book that can help me? (unfortunately the examples are not clear enough for those who have not used the palette yet)
‎04-29-2011 11:05 AM
hi,
this link can be of your use http://decibel.ni.com/content/docs/DOC-15408 .. just configure a little as per your need of AI ..
HS
‎04-29-2011 11:07 AM
Thanks. I appreciate it.
Baran.
‎04-29-2011 11:14 AM
Kudos are good for appreciation ..
Any way if you need any further explanation of that VI please post here.
- HS
‎04-29-2011 11:16 AM
Good to know. I was not familiar with the concept of Kudo. tnx.
