Has Anybody developed a means to controll the scroll position of a front panel in LabView 6.02
I'm trying to View a VI front Panel remotely, but the panel is to big to fit on the screen, so I need to be able to scroll up and down from my remote location.
I am using LabView 6.02
(2,689 Views)
There's no way to scroll the screen. You could however, use property nodes to move all the front panel object around in some sort of coordinated way--in theory at least. Personally though, I'd hate to have to write the code to do it.
In the past when I have had to do this sort of thing, I have used things like VNC (very good) or NetMeeting (horrible) to actually see the remote desktop. Both packages provide scrollbars for moving a small window around a larger screen.
You could also use some sort of networking to pul the data across the network and then create a screen on your local machine to display it.
Hope this helps...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,689 Views)
I was just playing around one day a wrote a horizontal scroll VI. I am not sure if this is what you wanted but I thought I might as well submit it.
(2,689 Views)
