Grayed out a button in NXG
Hello, I am starting to use labview NXG.
I would like to desactivate/activate some button while the code is running. I knew how to  gray out some button with the normal labview but I can't figure it out with NXG
I tried to use "modify variable propertie" function but I can't understand how does it work. Does someone have some info or an example.
Vincent
(3,140 Views)
Accepted by vincent20100
Create a reference to the button
Wire the reference to a property node
Choose the "Disabled" property on the property node
Set it to True/False to gray it out or make it normal again
(3,114 Views)
Thanks a lot Kyle,
but how do you create a reference to the button? On labview it used to be with a right click on the button but I find it in NXG.
(3,072 Views)
I found the solution. I used NXG 1.0. I updated to NXG 3.0. Now I can create the reference from a right click
(3,063 Views)
