Failed to Load Library Error When Using HTTP Client VIs in Ubuntu
I use Labview 15 on Ubuntu 14.04. I have a problem with HTTP Client VIs, for example when i use OpenHandle, it get me this message:"Error -1967362015 occurred at LabVIEWHTTPClient.lvlib:OpenHandle.vi:6450001
Possible reason(s):
OS and Network Services:  (Hex 0x8ABC7021) Failed to load library.
Complete call chain:
     Untitled 2"
How Cìcan i resolve it?
Thanks.
(4,365 Views)
Hello neptunus,
check out this link and try to see if it can solve your issue: http://forums.ni.com/t5/LabVIEW/HTTP-POST-on-LabVIEW-2012-for-Mac-Error-1967362015/m-p/2264606
Let me know.
Kind regards
(4,327 Views)
Thanks, but there isn't ni_httpClient.framework. in Ubuntu.
The error is:
Error -1967362015 occurred at an unidentified location
Possible reason(s):
(4,308 Views)
Did you ever figure this problem out? I am now currently having the same issue with the same version of Ubuntu.
(3,472 Views)
Have you had any luck on this?
I am experiencing the same issue.
(3,317 Views)
