Graphics
Hi everyone,
I'd like to know if it is possible instead of using number as scale style uses string or other stuff.
I know that in the graph properties/scale I can manipulate some itens.
What I mean is:In the Y-Axis instead 1,2,3 and 4 I want to use strings FPLAN,LAN,SDLC and UART
4
3
2
1
Y-axis
FPLAN
LAN
SDLC
UART
Y-axis
Thans
Kito
Message 1 of 18
(5,605 Views)
You may want to hack the example I posted here to do the Y-Axis instead of the X-Axis.
Ben
Message 2 of 18
(5,601 Views)
Thanks Ben. It's going to help me a lot. But, is there any easier way to do that?
Regards
Kito
Message 3 of 18
(5,571 Views)
Regards
Kito
Easier than having someone figure out how to do it ahead of time and pointing you to it? Smiley Very Happy
If there is I would very much like to hear about it, after all, I am here to learn.
Ben
Message 4 of 18
(5,565 Views)
Ben wrote:
Regards
Kito
Ben
I guess if he had LabVIEW 2009, he could just drag the code to his block diagram as a snippet.
That would be easier....
Cory K
Message 5 of 18
(5,560 Views)
Sorry Ben, I am a begginer. That's why I asked that. I couldn't do even that example that you posted it.
Regards
Kito
Message 6 of 18
(5,557 Views)
Also, since you want your text on the y-axis instead of the x,
you wont need any of the code that rotates the text.
There, that simplified it even more Smiley Very Happy
Cory K
Message 7 of 18
(5,555 Views)
Ben could you help me to fix my structure.
Following attached what I've done.
Regards
Message 8 of 18
(5,550 Views)
I like Ben's solution, and I believe there should be an easy way to do it.  Since you have fixed y values, why not make a little room on the graph, remove the existing scale (and title) and add some text labels by hand.  Disable y-axis autoscale and you are all set.
Message 9 of 18
(5,523 Views)
If you want this feature in an upcoming version of LabVIEW, please vote for my idea here. 😄
So far it did not get such a great response. 😞
Message 10 of 18
(5,514 Views)
