Graph issue with "scale object to pane"
I have made a program that  uses a mixed signal graph to show result on a screen. I have selected "scale object to pane". The program automatically goes to fullscreen when started. I have a small problem though. It works well with some screen resolutions but sometimes the graph itself is beneath the window. I set the Yscale Maximum and Minimum in the program but 0 is still below the border. Anyone know a way to fix this?
Pictures below
How it looks
How it should look
(3,578 Views)
Accepted by topic author Peter_Y
Hi Peter,
well, I don't like the automatic scaling of LabView as (usually) fonts gets distorted...
What about this:
Check screen resolution, then change the size of the graph accordingly... All this can be done using property nodes!
(3,572 Views)
Tried something like that and it works. I used the property node for the graph. Plot area > Size > Height and set it to screen resolution height - 120. 120 is for the the window itself etc.
But I wrote the screen resolution myself in an integer constant. How do I find out the screen resolution automatically?
(3,560 Views)
Hi Peter,
place a property node on the block diagram ("App" by default) and select Display->Monitor Smiley Wink
(3,551 Views)
