02-27-2018 01:37 AM
Hello everyone,
I have a question. We have a test station for production, and every time they run a test with TestStand, at the beginning and end of the test, the GSW appears. This is very annoying and I haven't found any solution for it. Does anyone have an idea what might help?
I already tried in LabVIEW:
Tools>Options>Environment> "Skip Getting Started Window", this just opens a blank vi during testing
Modify the labview.ini file, with the command: showNoNavDialog=True, also opens blank vi
Using:
Labview 15
Teststand 16
Windows 10
Greetings,
Jonathan
02-27-2018 07:23 AM
Have you tried to use the LabVIEW Runtime Engine instead of the LabVIEW Development Environment?
02-27-2018 07:33 AM
Yes, but we would need to switch every time we want to test or develop. We dont want to use the runTime Engine untill every testprogram works. Untill then we need to surpress the Getting Started window somehow.
02-27-2018 08:01 AM
You probably also saw this post (changing TestStand Window Activation on the run options tab of the step properties) but just in case...
02-27-2018 08:32 AM
Saw it and tried it. But with the second solution nothing happened. Instead of keeping Teststand in the front, the LabVIEW Getting Started Window was kept in the foreground.
