Getting error 42 with datasocket
Hi Folks,
I'm getting erro 42 with a simple datasocket read to a local network connection "http://172.27.72.70/versions", I can query other webpages such as www.google.com.   Any idea what I need to append to the front of this URL to get this to work?
I saw this http://digital.ni.com/public.nsf/allkb/27272FE3A32C334286257612004D9153
I don't know what this means:
"To work around this issue, you will need to append [text] to the URL wired to yourDataSocket Read.vi.  "
Chrome for example can display the info using the same command.
Any ideas?
LV8.6
-SS
(4,209 Views)
Accepted by ShotSimon
I usually find that the workaround means exactly what it says.  Change the connection string to:
http://172.27.72.70/versions [text]
(4,203 Views)
Hi Darin,
I was prepending itSmiley Happy  That worked - Thanks!
-SS
(4,192 Views)
