‎11-01-2016 05:38 PM
I am new to Labview and having a hard time connecting the dots to make programs work. What I am trying to do now is construct a vi that searches the values of an input array of numbers for a specified value. If the specified value is found in the array, the vi should indicate that by turning on an led and by indicating the corresponding index of the array. Any help would be greatly appreciated. Thank you.
Solved! Go to Solution.
‎11-01-2016
06:06 PM
- last edited on
‎03-05-2026
12:14 PM
by
Content Cleaner
You're looking for Search 1D Array. As long as this does not return -1, it found the element (turn LED on using this), and then assign the index to the correct location using the index it specifies.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/search-1d-array.html
‎11-01-2016 07:42 PM
While it's not a sexy as Search 1D Array, you could "do it manually" with a For loop, testing the values one at a time. If you've looked carefully at the LabVIEW Help for a For Loop, you'll see you can even stop the loop when you find the match.
If you cannot do this on your own (even if crude and slow), spend more time with the Tutorials and find yourself a LabVIEW Guru (or good instructor) to mentor you.
