Showing results forĀ
Search instead forĀ
Did you mean:Ā
Get software versions from RT system programmatically
Is there a way to get all the software versions from RT programmatically? Use cases would be something like writing a simple report of these versions on the RT drive for later FTP retrieval.
CLED (2016)
(3,213 Views)
Measurement I/O -> System configuration -> RT software -> Get installed software.vi
(3,196 Views)
Thanks! Unfortunately I don't think my target supports that VI. I get error -2147220364 if I run it on the host with the target in the VISA box and I get error 7 if I target local host from the target. Any idea which systems support that VI?
CLED (2016)
(3,186 Views)
poke around in the files on the RT harddrive using FTP. One of those files records that info.
Ben
(3,184 Views)
