Get data from a 2D array following the elements selected in a menu ring
Correct me if i am wrong but that doesn't account for if the data from the listbox is in the same order... i.e. listbox item 2 in column 2 >> data may actually be in column 3..
Could be having a brain fart here but..
Message 21 of 31
(3,221 Views)
yes... well just get the array of items you've selected and loop your search!!!????
Message 22 of 31
(3,221 Views)
In fact, when I did the solution suggested, it doesn't give me the right columns, when index the listbox
This is my list box :
If i select order 1, and it's number 2 in the list box i  obtain column number 2, which isn't for order 1 datas
If i select Order 24 , number 15 in the listbox, it gives me column number 15, however concretely Order 24 exists in column 4 .....
Message 23 of 31
(3,221 Views)
This is what i just did; I convert the listbox to a string array and index it, within a for loop, and I index the 2D array , use " search in 1D array" the elemnts of the listbox but It doesn't work, i get a 1D of (-1), it means it doesn't find the elements, so i used a case structure to have only >0 indexs but it doesn't work either even though I have done many trials
Message 24 of 31
(3,214 Views)
Sorry for misunderstanding then 😉
Might not be the best way to do it, but a quick idea here :
CLAMaxime -- Kudos are a great way to say thank you
Message 25 of 31
(3,212 Views)
Thank you so much Smiley Happy That works well to extract the columns related to the selected orders,
Still how to obtain the indexs of these columns in reference to the initial array.
Message 26 of 31
(3,205 Views)
Output theloop counter (integer) the same way as I did for the text array.
Message 28 of 31
(3,201 Views)
Accepted by Student_LV
you can use multicolumn listbox or table and get the index as well as data using point to row method, instead of searching.
edit:
modified VI
bp
Message 29 of 31
(3,193 Views)
Hi!
Thank you so much for your help,
 I made some other changes and finally it respond perfectly to what i want to doSmiley Happy
Message 30 of 31
(3,173 Views)
