Get continuous data in excel file from Instrument device using USB-RS232
Anything that I am doing wrong? Please also help me how to get time for the write to spreadsheet function. Thanks
Message 51 of 54
(785 Views)
Hi Intern,
  • You still don't provide cleaned-up block diagrams. Bended wires are hard to read…
  • You still forgot to provide all needed subVIs, many of them are missing. ZIP the whole project folder…
  • Why did you copy that filtering FOR loop with the same duplicated but unused output tunnel 8 times?
  • Why do your frontpanel items don't contain useful data? ("Response" is empty, "channels out" contains just a single sample in one of eight channels, graphs are empty, …)
  • Why is there a "Channels in" control, containing just empty channel arrays? Why don't you store previous channel data in a shift register? How do you want to create arrays of channel data when you don't keep them for the next iterations???
Message 52 of 54
(777 Views)
Hi GerdW,
Now I have attached the zip file with all SubVI by deleting some unnecessary functions in block diagram. I did the code this way as I had to finish the project by last Friday and I got the 8 graph from 8 channels and it was working. Sorry, I do not have answers for your rest of the questions that's why I posted it here so that I can learn more about it. Thank you.
Message 53 of 54
(768 Views)
Please help me to find the correct solution. Thanks
Message 54 of 54
(754 Views)
