Get continuous data in excel file from Instrument device using USB-RS232
Hi Intern,
forgot to mention with my snippet: You need to define the array constant with the appropriate number of elements for all channels. That snippet is just a sketch (it's not meant as "reliable working code")!
Message 31 of 54
(1,671 Views)
Thank you but I feel like, Its out of my league. I am stuck here for a week and tried other method but no luck. Some of the function you have used I can not identify them after searching all the function in the pallet.  Is there any other website of links that I look into to under your snippet better? I do not have access to all LabVIEW study materials.
Message 32 of 54
(1,658 Views)
Hi Intern,
Did you download my snippet and dropped it into the blockdiagram of a new VI?
Then you can use the context help to learn about all the functions/structures used!
Message 33 of 54
(1,655 Views)
Yes I tried but its do not have option to check. It is just showing as a whole.
Message 34 of 54
(1,652 Views)
Hi Intern,
  1. Download the attachment in my message to your harddrive.
  2. Open a new VI in LabVIEW, and switch to the block diagram.
  3. Drag and drop the downloaded snippet file into the block diagram…
Message 35 of 54
(1,649 Views)
Hi GerdW,
I tried again but still same result. I have attached the VI, how I am getting it
Message 36 of 54
(1,645 Views)
GerdW would you mind upload it again. Thanks
Message 37 of 54
(1,628 Views)
Hi Intern,
I'm sorry, I have the same problems like you downloading the snippet correctly. (See this thread…)
Message 38 of 54
(1,620 Views)
I have checked that I can downloads other png you have sent correctly and works fine but the last one having issues. I am using labview2020, so is it possible for you to send me the VI file or the function names that have been used. This way I can have some progress in my learning. Hopefully, the downloading problem get fixed quickly. Thanks
Message 39 of 54
(1,612 Views)
Hi GerdW Bro,
As still the problem with the downloads remains. Is there a way to give me some lead as I am stuck with my project as well? Thank you
Message 40 of 54
(1,572 Views)
