Get continuous data in excel file from Instrument device using USB-RS232
Hi Intern,
@InternlABVIEW wrote:
Hi GerdW Bro,
Please don't call me "Bro"! I'm not your bro… 🙂
As still the problem with the downloads remains. Is there a way to give me some lead as I am stuck with my project as well? Thank you
It seems the problem with downloading those snippets has been resolved now. I could download my last snippet and have attached it as VI now…
Message 41 of 54
(1,766 Views)
Sorry, I will call you sir now if you do not mind. As you are teaching me about LabVIEW. Thank you for the VI. I tried so many ways but can not get anything from the array. This is my VI now.
Message 42 of 54
(1,752 Views)
Hi GerdW,
Sorry if I offended you in anyway. Please help me finish this project as I have to finish it quickly. Thank you.
Message 43 of 54
(1,732 Views)
By using the Spread string to array. I can get array but it is not not storing values and I am getting all channels value in index 1. However, I still could out to fix the Array Index / Replace Elements Border Node to get data in array. Please help me here, I am new in LabVIEW and I have lack of knowledge in LabVIEW. My latest code is attached. Thanks.
Message 44 of 54
(1,715 Views)
My due date is tomorrow please help me. This is latest VI that I have been trying to get some thing from In place element structure. Still no result.
Message 45 of 54
(1,701 Views)
I have been working on a small project. I have to get 8 individual graph from the value I am getting from 8 individual channel. When I try to get a graph I am getting 0 when the VI reading other channel values. How do I fix this? My txt is the way the values are recorded.
Message 46 of 54
(1,719 Views)
I can extract the channel value separately and delete all the 0 from the array this way I can get the graph and value from the channel. But its not efficient way to do it. That's why looking for better solution.
Message 47 of 54
(1,691 Views)
The code works fine now but when I get the data in the file it comes like
Value1 0.000    0.000    0.000    0.000    0.000    0.000    0.000
From txt:
0.000    0.000    0.000    0.000    0.000    0.000    0.000    0.000
0.000    -1809.400    0.000    0.000    0.000    0.000    0.000    0.000
0.000    0.000    -1809.400    0.000    0.000    0.000    0.000    0.000
0.000    0.000    0.000    -1809.400    0.000    0.000    0.000    0.000
126.856    0.000    0.000    0.000    0.000    0.000    0.000    0.000
For that reason I can not draw a graph form a single channel as it gives a value 0 when not reading the channel value.
Is it also possible to get the value as: Value1 Value2 Value1 Value3 Value4 Value5 Value5 Value7 Value8 and draw sperate graph from each channel?
Message 48 of 54
(1,671 Views)
Hi Intern,
Where's the current version of your code?
Yes.
Message 49 of 54
(1,666 Views)
Here is my current version thanks.
Message 50 of 54
(1,662 Views)
