08-21-2013 03:24 AM
Hello everybody,
I want to know if it is possible to make a PWM signal with LabVIEW to control MOSFETs. My biggest Problem is the right hardware for this action. I would really appreciate any usefull Answers. Thank you for your time!
Grigory
P.S. the Datasheet of the MOSFETs are attached
08-21-2013 03:31 AM
What hardware you already have??? LabVIEW can only be used to control the PWM generation from right and compatible hardware, I've used M-series devices to generate PWM output, output in this case will be a TTL signal.
Refer to example attached here (go through complete topic for better understanding).
08-21-2013 04:04 AM
Thanks for your answer,
at the moment i am not using any Hardware we should buy new stuff for this Project. I was thinking about this http://sine.ni.com/ds/app/doc/p/id/ds-9/lang/de Module, since i read some other Posts about it. How usefull can this be? It should be able to work in kHz section. Also i need to able to set Duty Cycle and Period i prefer.
08-22-2013 02:55 AM
Just so that you know, you can also contact a Technical Sales Representative at your local branch if you have hardware related question before buying a product.
I am not really familiar with the datasheet of your MOSFET and thus I can not tell you if its good or not for it. What I can tell you is that the hardware you linked allows you to do some PWM with a TTL signal (meaning 0-5V). Would it be fitting your application?
08-22-2013 03:06 AM
Yes it would fit my Application, but i would like to know if it is able to vary period time of the PWM signal.
Grigory
08-22-2013 03:09 AM - edited 08-22-2013 03:10 AM
Refer to example attached here and you should be able to vary the frequency and duty cycle as well...!!
Edited: Well, I must tell you, this code works good with any M, X series devices using DAQmx functions.
