Generating Event with Subvi Control on Main Vi
It concerns me that you have two places that you are dequeuing the data.  And inside your lowest subVI, you are constantly adding elements to the queue.  I think you are trying to make things way too difficult.  Just pass the cluster out of the subVIs.  Then you don't have to worry about all of this syncronization and whatnot.  It will also simplify your state machines.
Message 11 of 12
(314 Views)
yes i need to deque the data at two places, i was not knowing that whem we are calling subvi as pop up window, we can pass values through it that's why i was not passing the cluster out of subvi, i will try this.
Message 12 of 12
(298 Views)
