Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
09-26-2023 07:34 AM
I'm locking for a solution for checking the state of an logical input of one PXI-6515 input (this one give the state of the inverte plug on the machine).
I check it every second but i would like to know if it's not possible to "regesiter" an event on this input state and generate this event at each state change ?
I see it's possible to générate VISA event ...but haow to link it to a pxi input ?
I use Ni Switch executive ....i see some trigger vi but i don't understand if it's possible to link this on my PXi-6515 input ?
Thank you so much for the help !
Solved! Go to Solution.
09-26-2023 08:44 AM
You can use Digital Change Detection. See How Do I Handle Digital Change Detection Events In LabVIEW?
09-26-2023 11:34 PM
Hello, Thank you so much ! it's exactly the (yeyword) i need ! I will try this now !
