Generate Interrupt / Event with the state of logical input on PXI-6515 possible ?
I'm locking for a solution for checking the state of an logical input of one PXI-6515 input (this one give the state of the inverte plug on the machine).
I check it every second but i would like to know if it's not possible to "regesiter" an event on this input state and generate this event at each state change ?
I see it's possible to générate VISA event ...but haow to link it to a pxi input ?
I use Ni Switch executive ....i see some trigger vi but i don't understand if it's possible to link this on my PXi-6515 input ?
Thank you so much for the help !
(837 Views)
Accepted by vincent69
You can use Digital Change Detection. See How Do I Handle Digital Change Detection Events In LabVIEW?
https://tmesystems.net/
(814 Views)
Hello, Thank you so much ! it's exactly the (yeyword) i need ! I will try this now !
(776 Views)
