04-20-2015 11:53 AM
Hi
from vehicle i am getting parameters Wheel Torque (nm), Engine speed (rpm), Main shaft speed (rpm) with respect to time in 2d array, please guide me to generate 1.5th or nth order torque from that?
Thnx
Prashant
04-20-2015 12:20 PM
Have you tried anything or thought at all about your problem before posting here?
04-20-2015 12:35 PM
Do you have problems with the math or with programming?
04-20-2015 12:55 PM
HI
I have attached the logic, but i m getting expected results so i hv doubt like i am using correct formula for getting 1.5th order wheel torque. So i need to help in finding correct formula or logic. i dont have any issue with programming just need help in finding correct logic.
Thank you,
Prashant
04-20-2015 12:59 PM
What is the formula?
