Garbled text
Hi all
I have a problem which is very irritating and time consuming.
I am using Labview 8.5.1 Developers Suite and sometimes when I load a VI the characters or digits are garbled, only showing boxes instead of their real value, they seem to work but it is impossible to
work with the VI, if I accidentally save the VI all my work is lost, because it alway loads garbled after that.
I have searched and searched on NI.com and I can´t find anything on the subject????
I attached pictures of the problem!!!
I REALLY hope that someone can help????
Thanks!
(3,541 Views)
Hey,
You can try to change the Application and System Font under the LabVIEW options to a defined font, like Arial. Maybe its a problem with the font you configured for your OS.
Christian
(3,505 Views)
This behavior normally occurs when using special fonts which are not present on the system.  So please check if you only use one of the three default fonts
- System
- Application
- Dialog
If so, you  may have issues in the sizing of the elements....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,502 Views)
I've had this happen when using a barcode scanner reading non-printable ASCII characters.  The other responses make sense to me.
Jim
(3,486 Views)
