GYRO_INDICATOR
Hi everybody...
we have to make one gyro Indictor using labview...
i have to kept the needle position should be static ... the numbers around the indicator should rotate... is there any posibilities are there to make the  indictor like that...]
if anybody knows please reply me....
am using LabVIEW2009.
Message 1 of 11
(4,675 Views)
You can use a dial and write to the scale.position start and range property, this will rotate the scale around.
This might not be the most elegant but should achieve the effect you desire.  You can hide the needle and overlay a decoration for the needle or you can also calculate the new needle positiuon and write this value to keep the needle from rotating with the new scale.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 11
(4,659 Views)
What do you want it to look like? Give us some idea and we can tell you if it will be possible in LabVIEW easily.
Tim
GHSP
Message 3 of 11
(4,655 Views)
Hello.
Perhaps this link can give you some ideas.
simulator
Best regards.
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 4 of 11
(4,642 Views)
Duplicate post
Try and keep your questions in one place!  Solution/example suggested in the other thread as well as here.
Message 5 of 11
(4,635 Views)
i have to show the angle from 0 to 360 degree..., i need to keep my angle indicator's needle should static(should not move)..., the numbers around the indicator should rotate to show the angle.......
Message 6 of 11
(4,618 Views)
Did you try the example I posted in the other thread?
The numbers rotate around a static needle. OK, the numbers go from 0 to 10 but to get to 360 all you have do do is type 360 instead of 10!
Wiggle the slider up and down to see it working.
Ian
Message 7 of 11
(4,605 Views)
Ian
Well I tried it and had fun playing with it.
even replaced the numbers with "NEWS" to the full compass look.
It entertained me. Smiley Wink
Ben
Message 8 of 11
(4,594 Views)
Glad to be of service! Maybe I should post some of the actual code I'm working on... thats even more entertaining (for all the wrong reasons! Smiley Sad  I'm considering changing my name to Rube this week)
Any clues as to how you did that?  I can't seem to figure out how to get strings instead of numerics.
Ian
Message 9 of 11
(4,589 Views)
Properties...
You have to sroll a couple of pages right to get at the tab that lets you define the Strings. The old version of the guage awa a lot easier. I'm sensing a little crtter in that config screen but I am not in a bug reporting mood.
Ben
Message 10 of 11
(4,586 Views)
