‎10-10-2015 10:15 AM
Nothing appears in my Functions or Controls palette and I don't know why!.. is there anythingt that I need to install?? FYI I have just installed labVIEW a couple of days ago.
‎10-10-2015 10:33 AM
You posted essentially the same question twice. You clearly have not properly installed LabVIEW. I suspect that much of the problem is the file (or files) that you are using for the installation. If you continue to have trouble, go to support.ni.com and "Ask an Engineer".
‎10-10-2015 02:05 PM
I wouldn't be surprised if it is an illegal copy of LabVIEW 2012 that he mentions in his other post.
‎10-12-2015
10:08 AM
- last edited on
‎10-14-2025
10:04 AM
by
Content Cleaner
Hello HalaR,
I've seen this issue before (even with LabVIEW 2015). Could you try following Step V (titled 'Icons or Palettes are Missing') at the following link? I've also pasted the relevant steps below.
LabVIEW 7.0 and higher
If those steps do not work (a restart of LabVIEW may be required), then I would suggest repairing your installation of LabVIEW. If the repair does not solve the issue then a reinstallation of LabVIEW may take longer but should properly install all the required resouces LabVIEW uses.
Are you using LabVIEW 2012? If so, then updating to LabVIEW 2012 SP1 via the NI Update Service may also fix the issue.
Please let us know if any of those steps prove successful. Have a nice day!
