Formula Node returning incorrect output
I don't see what is wrong in the equation I have entered. It is returning wrong output compared to my manual calculation. OriginalOriginal
Formula NodeFormula Node
Output (Original)Output (Original)
Output (Formula Node)Output (Formula Node)
Have I entered the formula wrong in the formula node or is there anything else I am doing wrong here?
(4,129 Views)
Attach your VI please.  It is a lot easier to debug a VI than it is to debug a bunch of pictures!
(4,120 Views)
Sorry. I have added two VI snippets now.
(4,105 Views)
Accepted by girish_jadhav
I see the problem.
You are using a comma as a decimal point inside the formula node.  Don't!  Use the proper decimal point of a period.
Read the context help for the formula node.  It says, "
  • Formula Nodes accept only the period (.) as a decimal separator. The nodes do not recognize localized decimal separators."
(4,076 Views)
Although it doesn't answer your question (which appears to be already solved), you might consider using the Polynomial Evaluation VI:
GCentralI'm attending the GLA Summit!
(4,041 Views)
That looks really neat.
Thanks for the suggestion. I am still a newbie and learning new things everyday 🙂
(3,988 Views)
