Formating a string to a number
Hi Jay,
@JÞB wrote:
Gerd, what is the search and replace doing in there?  Just use "%,%.6f" format string
I know about those formatting codes, but the OP apparently does not.
For simplicity and easier understanding of the OP I didn't change the OP's code for this specific code improvement…
Instead I want to improve the way the data is transferred from Arduino to LabVIEW.
Message 11 of 19
(1,195 Views)
Hey GerdW,
here is my code and the display on the front panel, here you can clearly see that i get the full data from the Arduino (or am i getting something completely wrong here?). The thing is that after the conversion to numbers i loose all of the digits except for the 3 after the comma. So i guess i have something wrong with either the conversion or so, so i will try to just save the string immediately and just convert to display the numbers even though the plot wont be 100% correct then. As you can see here i get all the data in LabVIEW just after the conversion and saving it it only Shows the 3 digits (also on the probes in LabVIEW itself as you can see in my first post).
Best regards and thanks again,
Mismatch
Message 12 of 19
(1,193 Views)
Hey crossrulz,
to 1: i know but i wasnt able to just put some time values into the file for a quick test so my solution was this i will try now to make it work with your point 2.
to 2: thank you the Write Text File VI worked just fine to get all the digits into the saved file 🙂
to 3: i will do that thank you.
to 4: Also everything is good in the csv then since i get a new column for every value.
to 5: i will try to clean my code up with all the unnecessary thing when i know what i need and what not, until now it is just the basic Programm so i can get started with some testing and when that works i would clean up my whole code to make it more user friendly.
Mismatch
Message 13 of 19
(1,173 Views)
Two things to check.
First: how is the display formatting set in Excel for column B. The default is %.3f because.....well, it's a spreadsheet.  BTW, Excel handles math a bit differently than the IEEE 754 standard for some cases.
Next: let's see the configuration inside the Express VI.  One of the reasons they are so hated is that they hide what you told them to do and don't have a default that fits every use case..
Essentially, you are getting yourself confused.   What you see in LabVIEW Front Panel Controls / Indicators and in Excel cells are text strings.  Known as a object's Display.Text.Text property.  A Value property is much different and is formatted into a display string by the owning application.
"Should be" isn't "Is" -Jay
Message 14 of 19
(1,184 Views)
hey ,
First: i tried to increase the commas and excel just adds 0 after the 3 digits, also LabVIEW already only Shows 3 digits with the probes.
next: here a screenshot of my configuration of the Express VI.
But since i already plan to do it with the string value and using the "write to text file" VI i don´t think this is necessary anymore.
I am just having struggles now with adding a time value for every string value i get into the file, but i guess this question was here somewhere already so i will look for a solution to this.
Mismatch
Message 15 of 19
(1,177 Views)
Hi mismatch,
Then why did you present completely different data in your attached VI?
How should I know the data you show now?
It could be so simple, once you get rid of ExpressVIs:
Why do you create a filepath with a ".csv" file suffix, but use the ExpressVI to create a XLSX file???
(Using the WriteTextFile function you can use a .csv file suffix.)
Edit: use the file reference coming from your FileOpen function instead of the file path to avoid overwriting the text file again and again!
Message 16 of 19
(1,176 Views)
Hey,
i did not change anything i just saved the VI as an older version, I didn´t know that could change anything so i am sorry for that. (never had this kind of data you have in your screenshot or that is in the VI i posted)
Yes thank you i will work with the string and the VI i got suggested now.
EDIT: These values were set as default that´s why they are in there like that, i didn´t realize this since normally i just start the Programm with the Arduinos connected so i get my normal values nearly immediately. Sorry for the confusion.
Mismatch
Message 17 of 19
(1,163 Views)
@Mísmatch wrote:
hey ,
Mismatch
See that Advanced button?
That pulls up a page that configures formats.
Probes in LabVIEW (Actually "Smart Probes") have a default format too!  Create new Probe with a %.20f specifier.  Just right-click the orange wire to launch the wizard.
Message 18 of 19
(1,162 Views)
Here it will just let me configure the Timestamp so i dint look into this at all.
Message 19 of 19
(1,157 Views)
