Move led to another page tab control programmatically
How i can move led indicator to another page of tab control programmatically?
(1,325 Views)
Hi Aritek,
You can do so using LV scripting as long as your VI is in edit mode…
Once the VI is in run mode you cannot move the LED to another tab page.
What exactly do you want to achieve?
When the LED should be shown "in" several pages then you should place that LED above the tab container (but not within!) and change the visibility of the LED if needed…
(1,318 Views)
... and if it should only be on some tab pages, create multiple LEDs wired to the same source. You can even make it invisible at time of needed.
IT ALWAYS HELPS TO DESCRIBE WHAT YOU WANT TO DO, NOT HOW YOU WANT TO DO IT 😄
(1,275 Views)
