Font Problem in Project Explorer
I am running LabVIEW 2013 SP1 and I just installed DAQmx 9.8. After installation it appears that something has changed with my fonts all throughout LabVIEW. The fonts keep getting cut off or cropped. This applies to everything from the splash screen, to project explorer to some of my VI font sizes. I went and verified my "System Font" and "Application Font" settings but didn't seem to resolve the issue. See the attached picture
Message 1 of 8
(4,856 Views)
Check the font size in Options>Environment as per the attachment.
Message 2 of 8
(4,816 Views)
It's weird that this change coincided wth the installation of DAQxm, though.  (Mine didn't change, for example.)
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(4,799 Views)
Accepted by craige
It ended up being related to the Windows 7 display settings. E.g. Right click on desktop, select Personalize, then select "Display". The system's window scaling had been set to Large and I had to change it to Medium.
Perhaps I hit some hot key while installing DaqMX. Very odd, but now its fixed.
Message 4 of 8
(4,789 Views)
Glad you found the solution - and thanks for posting it and marking it as solved, because I'm sure others will benefit from your trials.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(4,783 Views)
It seems I have the same problem. And I've tried to change font and scaling and neither are giving me results. Any ideas for why this would happen?
Thanks for your help!
Denis
Message 6 of 8
(4,027 Views)
As this is an older thread, I would suggest making a new thread for your question.  This will get more traffic across your question.
Niki Budgell | Product Planner - SW Management | NI
Message 7 of 8
(4,010 Views)
in LabVIEW.ini
appFont="default"
this worked for me.
Message 8 of 8
(989 Views)
