Find row in 2d array
please help...
i have 2d array of double and i wanna find specific row an extract to new 2d array.
My 2d array is:
100 31,3 25,3 32,1 25,6
160 32,4 25,5 33,5 26
170 33,2 25,8 34,3 26,2
100 33,9 26 35,2 26,4
and i wanna find row with numbers 100,160,170 and build new 2d array
please help....tnx, tnx
Message 1 of 8
(5,247 Views)
Send array to for-loop and use index array to check 1st element in each, Find in 1D-array (in your case 100, 160, 170) and if found add to result-array.
The outcome should be a 2d-array with the selected rows.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(5,234 Views)
tnx...can you be more specific..i still have a problem Smiley Frustrated
tnx
Message 3 of 8
(5,221 Views)
Accepted by ant_inter
I guess you should be more specific about your question. If you are planning to find the values that are present in the 1st column then you can use search 1D array and pass the index to index the 2D array so you will get 1D array of row then build the array by finding the element.
This is what Yamaeda explained
Message 4 of 8
(5,204 Views)
This might be helpful..
Message 5 of 8
(5,199 Views)
Instead of transposing your 2D array you could have indexed 0 to the column (as I have done).
Message 6 of 8
(5,189 Views)
Thats True P@Anand..
I have changed the code...Smiley Happy
Message 7 of 8
(5,183 Views)
It works super 🙂
Tnx both of you 🙂
Message 8 of 8
(5,157 Views)
