Put NI_report.lvclass into a cluster
I'm having a difficult time with trying to add a NI_report.lvclass to my cluster.
In my VI, I use the New Report.vi along with the Save Report to File.vi to generate some reports and then add data to the report as needed later on. Instead of using local variables to accomplish my task, I would like to place this (Raw Dara Report Indicator and the Summary Report Indicator) into my cluster for easy reference later. How do I do that?
My vi is attached, minus the sub vis which are not needed.
(2,836 Views)
You can drag a control or indicator into a cluster like you would any other. What is the problem you are seeing?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,826 Views)
I actually tried to do that. When I drag the indicator to the control, my mouse icon changes stating that I can't do it. I have my cluster defined as a type def.
(2,823 Views)
Oh, well you need to open the typedef and install it in the typedef - as you would any other control or indicator.
Mike.
LabVIEW Champion
(2,819 Views)
Found the issue. I was trying to drag items from the block diagram over to the type def cluster, which apparently isn't allowed.
(2,816 Views)
Yeah, you kind of need a control object or an indicator object not a terminal objectSmiley Wink It does make sense in some ways.Smiley LOL
"Should be" isn't "Is" -Jay
(2,807 Views)
Definately had a "senior moment" and I'm only 35. Smiley Very Happy
(2,776 Views)
