Filter nearest data on array
Hello
I have the array followed with these values and I need to filter these values by comparing the id value
In this case, I need to find the values closest to 1499 and the indices of these values (In this case they are 1500... 1554). In my application, all of these input values are dynamic, they are not fixed at these values.
Could you help me to do that?
(1,896 Views)
Hi Leandro,
There is only one value "closest" to 1499 and that is 1500… (Well, maybe there could be 2 values closest to target with the same distance, unless there could be more then one array element with the same value.)
Maybe you should start with defining your problem in a more accurate way?
Yes: use conditional output tunnels in your loop to keep only the values/indices of interest!
Other suggestion: instead of strings you should work with integer data. Atleast you could convert from string to numeric value once before the loop…
(1,887 Views)
It's just that all the data I'm receiving comes from a string, the previous treatment I didn't put here because it's not necessary.
I adopted the conversion suggestion before the loop.
But basically my application searches for data from a place and returns an array with several numbers, these numbers must be subsequent to 1499 (in this case), then I would have to filter the array and search only 1500, 1550, 1551, 1552, 1553, 1554. Which are the closest values to 1499 compared to the rest of the array
(1,867 Views)
Accepted by leandrofeder
A small change to your code will get you what you need
Tim
GHSP
(1,864 Views)
I just want to point out why this will never work: you have the min and max reversed.
As it is, the range is >=1599 and <1500. That won't work: no number is smaller than 1500 and larger or equal than 1599.
The coercion will work, but the in range output will always be false!
The range needs to be reversed.
I highly recommend you convert the strings to numbers as soon as possible. It's absolutely horrible to keep all data as strings, just because they came from a query or file or listbox, ring, etc..
Being able to see integers as integers, doubles as doubles, etc. will help you a lot in the long run.
(1,847 Views)
