File transfer using UDP
I am trying to send the entire file in one UDP write.
Message 11 of 22
(4,317 Views)
hi,
     you can use check(CRC-16 or CRC-32) verification mehode.and set port number both side same.
Message 12 of 22
(4,314 Views)
I have tried sending a text file but the last packets are missing.
I am attaching my code here.. Please go through it once.
Hima
Message 13 of 22
(4,309 Views)
Crosspost
Honestly not sure which thread has more discussion.
Message 14 of 22
(4,293 Views)
@Hooovahh wrote:
Crosspost
Especially since they are the same thread, just a new page...
Message 15 of 22
(4,277 Views)
See most of the time when I see a crosspost, one forum will have lots of discussions and replies, and the other has none, so I'll just point the thread with none to the one that is getting the attention.  But in this case I didn't catch it soon enough so both can be pointed to both, and you guys can figure out where you want to help.
Message 16 of 22
(4,269 Views)
No.  It is actually all in one thread now.
Perhaps someone merged the two threads together into a single one, this one.
Message 17 of 22
(4,261 Views)
What James has been telling you is correct.
The limit you are sieeing is due to the UDP protocol limitations. Datagrams were intended to be short and sweet and delivery was never gurenteed.
But you can CAN develop your own protocol that rides on top of UDP if you are determined. To that end, rather than re-invent the wheel, look into how TCP and IP work together to transfer larger messages.
UDP already has checksum built in so when a packet is recieved you can be sure it is intact.
You will have to break up the data file into small enough chunks to be transfered via Datagrams. You will also have to implement some sequencing logic so that recieving end can put the packets back together in the correct order because you could encounter a situation where one of many packets gets dropped and the reciever has to know which packet was dropped so it can request a resend of that packet. You should also "Ack" the packets that did get through so the sended side can check those off as done.
In a nutshell...
It can be done and all you have to do is recreate TCP/IP.
Ben
Message 18 of 22
(4,256 Views)
@crossrulz wrote:
@Hooovahh wrote:
Crosspost
No, I think the problem here was Hooovahh meant to post a link to the LAVA discussion but instead linked to the NI forum one.
Message 19 of 22
(4,234 Views)
@nathand wrote:
@crossrulz wrote:
@Hooovahh wrote:
Crosspost
@nathand wrote:
@crossrulz wrote:
@Hooovahh wrote:
Crosspost
Now that makes a lot more sense.
Message 20 of 22
(4,229 Views)
