Feedback- JSON text
I am new to JSON in general, trying to use JSON text to extract some info from my configuration file. I feel like there is an efficient way to do this. Basically, trying to create a VI to extract info based on the key & value pair I pass in. it works but looking to see if there is an efficient way.
attached json as a txt file.
Message 1 of 11
(915 Views)
Change the cluster array to a Map and it'll be cleaner. You also don't need the shift register and build array, just concatenate the array on the output (not needed with a map).
Something like this:
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 11
(779 Views)
Be carefull here, in the author implementation, all key / value pairs are concatenated. There are duplicates for each "signal_generators".  In yours, all key value pairs are inserted into 1 map, discarding previously already inserted key values.
@LVEnt it would be easier to help you if we have a JSON example / schema to work with.
Message 3 of 11
(743 Views)
I'm not sure how many records you have or how much access you need, but a SQLite database might be a nice choice. It's a "database in a file" format so you don't need a server or anything. The author of the JSONText library you're using also has a SQLite library and it's great.
Message 4 of 11
(723 Views)
Depending on how flexible you need this (like does "signal_generators" need to be a runtime input?) you could do all the filtering in LabVIEW after one JSON conversion.
Message 5 of 11
(709 Views)
I have a json config file attached to my OP.
Message 6 of 11
(699 Views)
I want to have the flexibility to add or remove a field in the json, so my cluster cannot be a constant. This is one reason I started looking into jsontext.
Message 7 of 11
(698 Views)
Accepted by LVEnt
Here's a different implementation that uses "find item.vi" to avoid one loop layer and does not create array elements that will not be needed.
For this to be somewhat robust you should try to raise an error (or otherwise handle) if multiple items or 0 items match the search criteria
Message 8 of 11
(676 Views)
can you attach the VI please?
Message 9 of 11
(655 Views)
Sorry, I missed it 😅
Message 10 of 11
(586 Views)
