Feedback- JSON text
I am new to JSON in general, trying to use JSON text to extract some info from my configuration file. I feel like there is an efficient way to do this. Basically, trying to create a VI to extract info based on the key & value pair I pass in. it works but looking to see if there is an efficient way.
attached json as a txt file.
Message 1 of 11
(2,186 Views)
Change the cluster array to a Map and it'll be cleaner. You also don't need the shift register and build array, just concatenate the array on the output (not needed with a map).
Something like this:
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 11
(2,050 Views)
Be carefull here, in the author implementation, all key / value pairs are concatenated. There are duplicates for each "signal_generators".  In yours, all key value pairs are inserted into 1 map, discarding previously already inserted key values.
@LVEnt it would be easier to help you if we have a JSON example / schema to work with.
Message 3 of 11
(2,014 Views)
I'm not sure how many records you have or how much access you need, but a SQLite database might be a nice choice. It's a "database in a file" format so you don't need a server or anything. The author of the JSONText library you're using also has a SQLite library and it's great.
Message 4 of 11
(1,993 Views)
Depending on how flexible you need this (like does "signal_generators" need to be a runtime input?) you could do all the filtering in LabVIEW after one JSON conversion.
Message 5 of 11
(1,979 Views)
I have a json config file attached to my OP.
Message 6 of 11
(1,970 Views)
I want to have the flexibility to add or remove a field in the json, so my cluster cannot be a constant. This is one reason I started looking into jsontext.
Message 7 of 11
(1,968 Views)
Accepted by LVEnt
Here's a different implementation that uses "find item.vi" to avoid one loop layer and does not create array elements that will not be needed.
For this to be somewhat robust you should try to raise an error (or otherwise handle) if multiple items or 0 items match the search criteria
Message 8 of 11
(1,946 Views)
can you attach the VI please?
Message 9 of 11
(1,925 Views)
Sorry, I missed it 😅
Message 10 of 11
(1,856 Views)
