Fastest way to add action engines to a project
I often use action engines in projects. Sometimes they are very specific to the data in my application, other times they check for elapsed times or send a message on a queue. Sometimes when I want two action engines with the same functionality (timers of 2 different events), I'll duplicate the files and re-name/re-icon before adding to my project.
Then I found out about LabVIEW libraries (.lvlib). I made a library (call it Timer_AE.lvlib) and implemented some standard vi's and wrappers: core, init, set interval, reset timer, check timer... Thanks to the library, I can have many "core.vi" in different libraries, and LabVIEW doesn't get confused. I can easily change the icons for a library all at once. It seems like a great way to do what I want, but I know that when dealing with LabVIEW it's always better to deal with toolbars and pallettes in LabVIEW rather than copy+pasting in windows explorer.
Am I abusing the LabVIEW libraries? Does LabVIEW have a built in way to do what I am describing?
Message 1 of 20
(5,064 Views)
You are abusing lvlib just a bit.
Have you considered "Project Templates?"  That and a bit of lvlib mojo to keep the "Core.vis" private and expose the API by "Going to Nirvana" with your Action engines... (enough said by me untill I know your use case and user base)
"Should be" isn't "Is" -Jay
Message 2 of 20
(5,050 Views)
My simple Action Engines (such as Timers) I save as LabVIEW Templates (.vit) and keep them (typically) outside my Projects, but available from File/New ... under User Templates.  When time to save, I name them appropriately for the Project and save them inside the Project.  Each one has a unique (and, I like to think, mnemonic) name, which I find helps me to "self-document" my code.
Message 3 of 20
(5,040 Views)
One again, Jeff beats me to the draw ...
BS
Message 4 of 20
(5,035 Views)
Hi Jeff,
I have not considered project template, I have never made one before. You are correct that I set the scope of the core.vi to private. Sometimes I do not realize that I want an AE until I've gotten a little ways into the project, would a project template mean that I have to use it as a starting point?
Message 5 of 20
(5,031 Views)
Hi Bob, I will have to look into .vit's. Yes, I rename mine as well within the project explorer so that LabVIEW can make all the correct connections. And I don't think I'd be allowed to have two "Timer.lvlib" in the same project. I was expecting your signature: Bob (beaten to the draw) Schor  Smiley Tongue
Message 6 of 20
(5,027 Views)
Couldn't sign it until after I posted and noticed Jeff hit "Post" a minute before I did ...
Bob (chagrinned) Schor
Message 7 of 20
(4,999 Views)
Kudos for using "File New..." rather than "Ctrl+N
Nothing to be chagrinned about!
Project Templates are a great way to pull re-usable code into a new project that still maintains name-spacing.  True re-use code would be written without bugs!  Unless you have a "Bug Tracking" system or, can afford the "Burden Hours" to support the internal code you can't charge to a customer,... these project templates will save you hours per deliverable executable.
Message 8 of 20
(4,978 Views)
Can I save a group of VIs as a template, or do I have to save them one by one? Or do you make a "Tree.vi" that has all of the subVIs on the block diagram so that you can pull them all into your project at the same time?
Message 9 of 20
(4,919 Views)
You have to make individual templates.  However, if you put all of your templates in the same folder, you can just add that folder to your project.  I could also argue that templates do not belong in the project at all, but in your reuse library.
Message 10 of 20
(4,906 Views)
