Running a LabVIEW executable (developed on Windows machine) on an Ubuntu machine
I'm right now experimenting with a C++ program on a machine running Ubuntu 16.04. What I'd like to do is get the C++ program to somehow integrate/incorporate/play nice with a LabVIEW 2014 executable developed on a machine running Windows 10.
Here's my question (and I realize I'm likely asking the wrong question): is it possible for a LabVIEW 2014 executable developed in Windows to work in Ubuntu, provided all the necessary drivers are installed?
(2,821 Views)
Are you using Wine on your Ubuntu?
Did you try installing LabVIEW Run-time engine within Wine?
If it works I believe you could run your exe in that environment?
(2,807 Views)
Possible? Yes, in theory.
Reality? Chances are slim to none.
Maybe if you can get the proper LabVIEW run-time engine to install in WINE and your program does not do any sort of hardware access or use VISA, NI-DAQ, or rely on any other hardware abstraction layers or NI tool-kits it might run.
=== Engineer Ambiguously ===
(2,805 Views)
