Failed to Load Dynamic Library
I am using LabVIEW 2013 (SP1 - 32-bit).  I created a sub vi called trigger.vi during last week.  From the main VI I compiled an executable which works fine.  But now when I try to open the sub VI  file I receive the following message.
trigger.vi is my own file which I tried to open and the sub-vi's on which it depends is avaliable.  From the main VI this particular VI is shown as an "?" and I cannot replace it.
Any suggestions?
(5,320 Views)
Yes, this VI is damaged. I can not open it.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
(5,290 Views)
Does the question mark look like the one on the table of the next link?
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/environment/project-explorer-window-icons....
It looks like Colin is probably right, this VI might be damaged, in wich case, I hope you still have a working copy of it.
(5,263 Views)
