FTP Get File Help
I've used the command console to FTP files from the camera, using windows file paths, and that worked, so how is that the problem?
Message 11 of 13
(1,006 Views)
Very much a duplicate thread to this: http://forums.ni.com/t5/LabVIEW/Lab-View-FTP-Put-File/td-p/2965605
As explained there, use Unix path syntax for the remote path. FTP comes from Unix systems and NI choose to implement the interface to the FTP VIs accordingly (which is a good choice considering that LabVIEW can run also under Linux and MacOS X).
Rolf Kalbermatter  My Blog
Message 12 of 13
(990 Views)
Yeah, I'll try it that way
Message 13 of 13
(983 Views)
